Question Cannot post to forum, not sure why?
14 years 8 months ago #105877 by Matias
Ok, found out what's the issue. Looks like our code tag doesn't behave too well on long inputs.
Issue seems to be fixed in K2.0, though (we replaced the parser).
14 years 8 months ago #105958 by gwmbox
Ok here is the source attached, hopefully you will be able to see the issue so I can have forum posts again
Thanks GW
14 years 8 months ago #106307 by Matias
I can see the issue, but I have no idea how to fix it as our current BBCode parser was written from someone who disappeared some time before Kunena 1.0. Nobody understands how the parser really works. I know what is the issue, but if I try to fix it, the whole parser breaks and I haven't been able to figure out why.
Quick workaround is to make smaller posts (code tags) or use some other tag instead.
14 years 8 months ago - 14 years 8 months ago #106493 by gwmbox
Ok, now we have sorted out why your forum is not allowing long code posts can we get back to trying to work out why my forums are not allowing posts?
GW
Last edit: 14 years 8 months ago by gwmbox.
14 years 7 months ago #107399 by gwmbox
Hello, can I get some help please, I am still unable to post to my forums, help needed please.
GW
14 years 7 months ago #107613 by Matias
I've been busy in other tasks.
If you mean that it still doesn't allow you to post long code snippets, there's not much that I can do. Nobody knows precisely how the old BBCode parser from FireBoard works and we have already replaced it in upcoming Kunena 2.0 (where your code works just fine).
Time to create page: 0.227 seconds
