Question Cannot post to forum, not sure why?
14 years 8 months ago - 14 years 8 months ago #105554 by gwmbox
Hi all, I have a site at dogsites.com.au with Kunena installed that was working fine but it is for some reason no longer allowing posts to be added to the forums. I cannot recall anything that I have done would have caused the forums to allowing posts, I have not altered any part of the forum system pre the upgrade so cannot figure out why I am having these issues.
I have updated it to 1.7 and also Joomla 1.5.23 and tried the default template and still no help. So here I am asking for help, anyone have some things I can try that may fix the issues I am having?
Some other 'possible' conflict components are
JomSocial 2.0.6
Flyspammer blocker 1.1.2
tagmeta 1.4 Ent.
xmap 1.2.11
plus others but I cannot see how they would affect Kunena
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 192M | Max file upload: 100M
Joomla default template details : dgsflexi | author: Dogsites | version: 2.6.0 | creationdate: 18/02/2011
Kunena default template details : DGSFlexi Template | author: Dogsites | version: 1.0.0 | creationdate: 2011-01-31
Third-party components: Jomsocial 2.0.6
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Discuss 1.6.2
Modules: Kunena Latest 1.6.2 | Kunena Login 1.6.2
GW
Last edit: 14 years 8 months ago by Matias. Reason: Put report inline
14 years 8 months ago #105556 by 810
Please update jomsocial , kunena modules. and try with default temple.
regards 810
14 years 8 months ago #105559 by Matias
You should also update Kunena Latest and Kunena login. FYI: you have two login boxes in the forum, please remove one of them (either module or disable login integration from Kunena)..
I have no glue what could cause posting to fail. What happens when you try to post? Do you have the same issue with administrator (who doesn't have any limits in Kunena)?
Also try to enable debug mode, that will probably reveal what's happening.
14 years 8 months ago #105570 by gwmbox
810 wrote: Please update jomsocial , kunena modules. and try with default temple.
regards 810
I have tried the default template as I said above. JomSocial update I will try also later, but not sure why that will impact, as well as the module updates (thanks)
GW
14 years 8 months ago #105571 by gwmbox
Matias wrote: You should also update Kunena Latest and Kunena login. FYI: you have two login boxes in the forum, please remove one of them (either module or disable login integration from Kunena)..
I have no [strike]g[/strike]clue what could cause posting to fail. What happens when you try to post? Do you have the same issue with administrator (who doesn't have any limits in Kunena)?
The same happens as Admin and Registered user.
I will debug more and see what happens, thanks for the suggestions.
GW
14 years 8 months ago #105573 by Matias
First I would check if all the database tables are OK:
1) phpMyAdmin: check all tables
2) Log into administration and check this URI: administrator/index.php?option=com_kunena&view=install&layout=schema
Joomla debug should also reveal possible SQL issues.
