Question Menu Tabs
I then removed all menu items from kunena. Pressed the make menu link again. Then removed all the items again and after the 3rd try the forum worked correct. Tabs don't disappear anymore.
Hurr1c4n3 wrote: I then removed all menu items from kunena. Pressed the make menu link again. Then removed all the items again and after the 3rd try the forum worked correct. Tabs don't disappear anymore.
Okay, i will try this too tonight.
This is not working for me
I am unable to get any tabs at all to show up.
If you browse to /forum, the menu doesnt show.
If you visit any menu item's alias like forum/index, forum/help etc.. Then the item shows.
(Incidentally, the kunena_msg_x for ad placement doesnt't seem to work either, but i'll open a topic on that if I see the issue)
When upgrading to a newer version, the Kunena Menu is automatically created but tabs are not shown.
Tried to delete it and rebuild it with the button from the backend Kunena config, but no success.
Tried to delete it and rebuild it manually, but no success yet.
