Question Menu Tabs
16 years 3 months ago #57069 by Masonox
Menu Tabs was created by Masonox
I wasn't able to find what I was looking for, but how do I create the menu tabs at the top of the forums? I did not see any Kunena menu in the Joomla Menu section, and my forum has no naviation.
thanks for link, or help. Version 1.6
The topic has been locked.
16 years 3 months ago #57072 by xillibit
Replied by xillibit on topic Re: Menu Tabs
Just go in Kunena control panel and use the function create menu, you don't need to do something else. More information on menus : docs.kunena.com/index.php/Creating_customized_menus
16 years 3 months ago #57085 by tromp
Replied by tromp on topic Re: Menu Tabs
My menu was woring in 1.6 beta, but disappeared in 1.6 RC
16 years 3 months ago #57087 by xillibit
Do you have tried that
xillibit wrote: Hello,
Are-you on joomla! 1.5 or joomla! 1.6 ?
16 years 3 months ago - 16 years 3 months ago #57089 by Masonox
Replied by Masonox on topic Re: Menu Tabs
unfortunatly this didn't help me at all I did not see any of this
Creating Menu Item to Main Menu
When you setup Kunena for your site, it's important to add menu item to your main menu. Kunena already does this during installation by adding Forum to Main Menu. But you should take a few minutes of your time to do it better.
1. Go to Menu Item Manager: Menus >> Main Menu (or your own menu)
2. Edit Forum (or create new menu item) ******had to create this
3. Change Type: Alias ********** didnt exist, used
4. Parameters (Basic) >> Menu Item: Kunena Menu - Top >> Forum ******** don't understand this, there was no kunena Mneu - top forum?????
Might retract this, I might have found it.....
Last edit: 16 years 3 months ago by Masonox.
16 years 3 months ago #57092 by Masonox
Yea, found the create menu button, but it did not create a menu.
and
this information was not present either, and after clicking create menu, there is still no menu on the forums.
