- Thank you received: 4
Question Menu Tabs
16 years 3 months ago #58411
by MindTooth
Replied by MindTooth on topic Re: Menu Tabs
As with everything in Joomla!, when you create a menu item for a component. That link will be highlighted as active when clicked and the page is rendered.
Just with this site. I am sure when you read this, you can scroll to the top, and see that the Forum tab has a blue background as a highlighted state.
This is what I am talking about. I can't seem to create a menu link highlight and both keep the Kunena menu. Sorry if I elaborate to much and in turn makes my writing useless
The topic has been locked.
16 years 3 months ago #58417
by Matias
Replied by Matias on topic Re: Menu Tabs
This tells some basics on how menu should be used:
docs.kunena.com/index.php/Creating_customized_menus
You just need to learn how to use Joomla menus
16 years 3 months ago #58419
Replied by sozzled on topic Re: Menu Tabs
Thank you for your explanation. As I said before, this discussion topic has been very broad ranging. As you can expect, with a subject heading like "Menu Tabs" it could mean just about anything.
This is what I propose to do. When we have resolved your issue I am going to lock this topic so that it does not further become a "catch-all" for every possible problem that involves the K 1.6 menu tabs.
I understand your question, MindTooth. You cannot get the Kunena CSS to work on your website. There are three possible causes:
(1) You have not enabled Mootools on your website.
(2) You have changed your K 1.6 template and there is nothing in your CSS file to handle the mouse hover condition.
(3) Your site template CSS is overriding the Kunena template CSS.
Can we eliminate the first two potential causes, please? In the event the third potential cause is all that's left, what happens if you use the rhuk_milkyway template instead of the site template that you are currently using?
The following user(s) said Thank You: Bedo
16 years 3 months ago #58424
by MindTooth
You never learn
Previously we had a very slow load of the site. Which were caused by our template. And yet again, this is the root of our new problems as well.
Just loaded Gantry on a demo site, and the menu works perfectly
Thanks for the idea of testing it with an another template.
Sorry for any bad behavior made by me
16 years 3 months ago #58426
:laugh: NP. I'm very glad to hear that we were able to help in a small way.
Now that this matter has been resolved and before the topic is unintentionally "hijacked" in some other way, I am locking this discussion topic. If others have specific problems or issues relating to K 1.6 menu tabs, please start a new discussion topic and please try to describe, in the subject, a few words about what is wrong with the menu.
Thank you for your co-operation.
