Question [Resolved] Attached images are uploaded but not displayed
14 years 11 months ago #112950 by sozzled
Very good. You've checked the permissions for that one file. What about the permissions of the folder it's contained in? And the folder above that one? And the folder above that all the way back to the root?
The topic has been locked.
14 years 11 months ago #113000 by Focus123
:) They are all according to the recommended ones.
14 years 11 months ago - 14 years 11 months ago #113001 by sozzled
Focus123 wrote: If I have no positive result I will write back with a test account details.
What happened to that idea?
Last edit: 14 years 11 months ago by sozzled.
14 years 11 months ago #113119 by Focus123
I have created a "test" website on my PC (Windows XP using WAMP and Akeeba) and replicate the entire website. The strange thing is that the Kunena attachment problems are not present on my PC ... I am really confused here. I will check next week with the web provider if they performed any changes on my web account, though I doubt it.
14 years 11 months ago #113121 by sozzled
As we have been trying to say, for a long time, there look to be permission issues on your hosted site. These may be because of the version of PHP that you're using, or the way that the folders/files are owned, or the permissions on the folders/files themselves. Did you try disabling MIME check in Kunena settings?
14 years 11 months ago #113123 by Focus123
Yes - I did try to disable the MIME check in Kunena (though I felt that was just a check for uploads - not for showing the actual picture). I am having the feeling that some software modules need to be reset on my web services provider. Is there any positive experience on this?
