Important [Merged topic] J! 1.6+: PDF feature does not work
15 years 6 months ago #93716 by sozzled
The PDF creation in Joomla is very basic. As I recall (I haven't used the function for a long while) there is no image representation in a Joomla-generated PDF function. Maybe someone else can confirm this?
15 years 6 months ago #93761 by cally6008
Ahhh, I thought it was Kunena doing the PDF creation not Joomla. I'll head over to Joomla and see if I can find anything to help. I've tried the PhocaPDF but don't think it's working.
15 years 3 months ago #103475 by Jiminimonka
I have installed Kunena on 3 different website, and in each installation, even though I have the PDF option enabled in Kunena config, there is no PDF Icon on any of these forums.
I checked if the template was the problem by trying the default ones as well as custom ones, and in all instances the RSS feed icon is visible on the main page, but in the posts, its either no icon, or just the RSS feed icon.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 32M | Max file upload: 20M
Joomla default template details : jm_biz_purple | author: jm-expert! | version: 1.0.2 | creationdate: 1 March 2011
Third-party components: UddeIm 2.5
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.6.4
Modules: Kunena Latest 1.6.4 | Kunena Login 1.6.4
Please read the FAQ.
Only one question per topic.
15 years 3 months ago #103501 by xillibit
Replied by xillibit on topic Re: No PDF Icon
The pdf icon is present but only for topic, like here you will see a pdf icon in the bottom of the page
15 years 3 months ago - 15 years 3 months ago #103545 by Jiminimonka
Replied by Jiminimonka on topic Re: No PDF Icon
I checked that, and there is no PDF icon in any topic, on any page of my forums. I have asked other members to check for the PDF icon as well in case it was something at my end, but they can't see it either, and it is definitely enabled in K! admin.
Added 2 screenshots, both from different website, one is a fresh install, with nothing but Joomla 1.7 and Kunena 1.6.5.
Last edit: 15 years 3 months ago by Jiminimonka.
15 years 3 months ago #103565 by Matias
Replied by Matias on topic Re: No PDF Icon
Joomla 1.7 doesn't have PDF support built in. Feature is disabled in it.
The following user(s) said Thank You: Jiminimonka
Time to create page: 0.152 seconds
