Important [Merged topic] J! 1.6+: PDF feature does not work
15 years 3 months ago #103582 by Jiminimonka
Replied by Jiminimonka on topic Re: No PDF Icon
Thanks, at least I know that's not something I messed up :)
Please read the FAQ.
Only one question per topic.
15 years 4 weeks ago - 15 years 4 weeks ago #109811 by MfGLucker
Replied by MfGLucker on topic PDF-Icon not shown
i know it a time long, but today i wanted to ask about it.
Equal what i do, i cannot see the pdf-icon after a post in my forum.
It is since i installed a few months ago my website mfg-esports.com
RSS-Icon is working, but not proberly. But that is not important for me, because we dont use it.
Here is my Configlog
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : gored_ultra_lernvid.com-j1.6 | author: Juergen Koller | version: 1.0 | creationdate: Apr 2011
Third-party components: CommunityBuilder 1.7 | UddeIm 2.5
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.7.0
Modules: Kunena Latest 1.6.4
Sammle erst die Fakten, dann kannst du sie verdrehen, wie es dir passt.
Mark Twain
Last edit: 15 years 4 weeks ago by MfGLucker.
15 years 4 weeks ago #109812 by 810
Replied by 810 on topic Re: PDF-Icon not shown
yes, the pdf is only woking on J1.5.x Thats why we removed it from k2.0.
regards 810
The following user(s) said Thank You: MfGLucker
15 years 2 weeks ago #110708 by chgeiselmann
Dear all,
There was an issue with pdf generation in Kunena 1.6. As opposed to Kunena 1.5, pdf printout of Kunena forum threads in Kunena 1.6 was not possible, since the Kunena team understandably had not enough manpower to deal with this (minor) task at the time (see the respective forum discussion here).
However, I would like to know: Has pdf generation been re-implemented in the current 1.7.0 version?
I am asking because, if so, I would update one of my forums to 1.7.0, since users there definitely are asking for such a possibility. If Kunena 1.7.0 does not offer this feature, I would leave my installation as it is, since it runs smoothly, and, well, never change a running system. :-)
Thank you for your help,
Kind regards ,
Christian Geiselmann
15 years 2 weeks ago #110728 by xillibit
Before Kunena used libraries in Joomla! 1.5 to generate pdf, but since Joomla! 1.6 the libraries has been removed.
14 years 9 months ago #117531 by flozzilla
Hello Kunena Team,
first, thank you for that great Software.
I use Joomla 2.5 with Kunena 1.7.2
I spend hours, to find out WHY there is no PDF Button in the Frontpage although there is the right setting PDF -> "Yes" in the backend.
Now I know, that Joomla is not supporting PDF anymore. Since >=1.6
I need that fine User Account Control from Joomla 2.5 :)
But also the PDF Function is important for me.
QUESTION:
Is there any possibilty, to make a Work-Around. I tried phoca PDF, but that gives me only a button for the articles.
thank you,
for any idea,
Flo
Time to create page: 0.157 seconds
