Important [Merged topic] J! 1.6+: PDF feature does not work
15 years 8 months ago - 14 years 9 months ago #87888 by Josh07
I have the PDF option enabled in the configuration but the icon does not show up on the bottom...any ideas how to make this work?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 8M
Joomla default template details : bizconnect | author: mambasana.ru | version: r1-j1.6 | creationdate: 13/02/2011
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: The file doesn't exist comprofilej.xml ! | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Last edit: 14 years 9 months ago by sozzled. Reason: Merged several topics; changed subject to improve search relevance
15 years 8 months ago #87889 by sozzled
Thank you for your question, Josh. The feature you refer to has been disabled in K 1.6 and the option you refer to in the forum configuration settings will be removed.
There are other alternatives to creating PDF version of web pages. Most browsers these days have PDF-creation add-on functions. I suggest you use Google to search for those kinds of things. :)
15 years 8 months ago #87983 by Matias
sozzled meant that feature doesn't work in Joomla 1.6 because of there's no libraries installed to do that (feature was removed from Joomla).
15 years 8 months ago - 15 years 8 months ago #88001 by Josh07
Thanks for the reply. The reason I was looking for a PDF creation is because my site is made up of many categories and sub categories and the last level of categories has 10 topics. Since there is no PDF feature is there an easy way to load all 10 topics and reply's onto a new page in that specific category?
I was thinking a variation of the RSS feed might work but I can't get the icon to show up in subcategories, just main category and recent topics.
Any Suggestions on how I could get this?
The site is www.thesermonbuilder.com
Last edit: 15 years 8 months ago by Josh07.
15 years 8 months ago #88003 by Josh07
Also thanks for the clarification Matias. I cam blame Joomla 1.6 not you guys for it not working... :P
15 years 6 months ago #93715 by cally6008
Kunena 1.6.3
I've enabled PDF creation which works fine.
The only problem is that photos attached to the topic do not show in the PDF
This is not a problem as hosting the photo on my website allows the photo to show
The actual problem is the size of the photo in the PDF, it is much smaller than in the topic
I'm not sure where I should be looking to play at getting the photo to its orginal size
Time to create page: 0.151 seconds
