15 years 5 months ago #97476 by NoFxPT
Thanks. <script type='text/javascript' >jQuery.noConflict();</script> before the </body> tag solved the problem.
15 years 5 months ago #97498 by Dprince1
Replied by Dprince1 on topic BBcode missing
alright im stuck and need help with this
i dont know how to fix it and im really lost.
15 years 5 months ago - 15 years 5 months ago #97502 by sozzled
G'day, Dprince1, and welcome to Kunena.
Please see msg #1 in this topic.
Last edit: 15 years 5 months ago by sozzled.
15 years 5 months ago #97508 by Dprince1
i have check my mootools and my current version is Mootools 1.2.4
15 years 5 months ago - 15 years 5 months ago #97510 by sozzled
That's good to know but that is only 0.1% of your problem solved. The answer is not whether you have Mootools 1.2.4 installed or enabled, the answer lies in finding out what other Joomla extensions you have installed that are clobbering Mootools 1.2.4 and dealing with them. Please read the links in msg #1 in this topic.
15 years 5 months ago - 15 years 5 months ago #97512 by Dprince1
i have read all the way through, and i think its my template, but i have seen this template work before.
Everything works great when i switch to the default template. i must have missed something somewhere.
k so ive been looking through my site with firefox with the firebug plugin and found this,
MooTools.More={version:"1.3.0.1
there is nothing about mootools itself, just that.
im back to the lost stage..
also found this with firebug
$(document.body).adopt is not a function
[Break On This Error] var Slimbox=(function(){var F=window,n...loop&&(g.length>1);return b(O)}}})();
if that has anything to do with it. if not then just disregard
also i have noticed that my theme is for version 1.6.0, how do i update it to make sure that it is not the issue.
Last edit: 15 years 5 months ago by Dprince1.
Time to create page: 0.161 seconds
