15 years 6 months ago #94674 by levalencia
solved the edit issue thanks
15 years 6 months ago #94959 by accannon
Hey guys, sorry to bother everyone w/a common problem, but I can't seem to figure this one out. I recently created a Kunena Forum on my site (a great forum tool by the way). I activated the MooTools upgrade plugin, and everything works great, except no user can "edit" their profile. When they click on their profile, all the normal tabs appear and work, but the "edit" button moves from the right side to the left next to the user's name and is no longer a link. Is this a template issue or is there a config I'm missing. Here is a screenshot. Any ideas? It's using Joomla 1.5 with Kunena 1.6. It is using a Rockettheme "Dominion" template.
15 years 6 months ago #94964 by xillibit
You have a common issue where the edit button is misplaced, there is a conflict with your template
15 years 6 months ago #94968 by accannon
Yup, your absolutely right. Switching to the default joomla template it removed this issue. Do you have any experience in how to config a template if it experiences this issue? I'm contacting Rocketheme now, but if someone here has dealt with this if you can let me know how to modify this that would be great, thanks!
15 years 6 months ago #94969 by accannon
You know what - Disregard, I figured it out. Well, sorta.
It has to do with custom css titles. On the template manager, if you disable "Build Title Spans" it works. Since I don't use any title spans, this is fine. If I can figure out how to enable this and still make it work I'll post it again.
Useful info for anyone running into this issue though ;)
Thanks for the quick response!
15 years 6 months ago #94974 by accannon
Here's another workaround -
1 step: copy this file
joomla-root/components/com_gantry/features/jstools.php
into this location
joomla-root/templates/template name/features/
2. step: open this new jstools.php
find line 45-47
if ($gantry->get('buildspans-enabled')) {
$modules = "";
$headers = "";
and change it to this
$modules = "";
$headers = "";
Works like a charm, and you can keep Build Title Spans on for the rest of your articles. I haven't found anything broken w/this yet, so this seems to be the best solution.
The following user(s) said Thank You: JuggZaPoppiN
Time to create page: 0.147 seconds
