- Thank you received: 2
Thanks for the help.
I have been trying to figure out how to solve this problem and have read through many posts on this forum to no avail. One suggestion was to upgrade MooTools (which I did, to 1.2.5) but that did not help. The error I am getting is:
Error: $("kBulkChooseActions").addEvent is not a function
Source File: www.easyfitmom.com/components/com_kunena...efault/js/default.js
Line: 758
Here is a direct link to my forum. Guest posting is enabled for troubleshooting purposes.
www.easyfitmom.com/com_kunena_menu_forum...s/2-Welcome/post/new
Thank you in advance for any help you can give. I am at a total loss!
Deb
Joomla Version: 1.5.23
MooTools Version: 1.2.5
Please read msg #1 in this topic.
I was in the middle of writing here with all of the things I tried (to no avail), and then I decided to switch templates to see if that would help -- and that did it. Phew! Duh me
Thanks!
Deb
- ebcHosting
- I believe, taht I made a problem during previous upgrade Joomla, last is correct (logout first from admin, then upgrade)
- I did re-install the forum
- I accidentally uninstalled SEF plugin, that comes with joomla
Joomla Version 1.5.23, Installed version: Kunena 1.6.3 (Blue Eagle (default) template)
Systen plug is in the following order
System - Kunena - Enable
System - Captcha - Disable
System - Debug - Enable
System - Legacy - Disable
System - Mootools Upgrade - Enable
System - Cache - Disable
System - Log - Disable
System - Remember Me - Enable
System - Backlink - Disable
System - Vinaora Visitors Counter - Enable
System - KeyCAPTCHA - Disable
How can i fix problem with bbcode and profile edit... ??????
Adress is : www.ebchost.info
