15 years 6 months ago #94145 by miro
Oh yeah!!!! I've done it, guys youre great thx for help! :evil:
Ive disable rokbox and rokcandy, then BBCode window above the new post window is visible ;D
I'll check the profile's...
okay work's fine :)
15 years 6 months ago #94220 by Domino
Replied by Domino on topic Can't edit profile
I wonder if someone can help me this is the first time I've uploaded a forum to a website, Everything seems to be working fine but I can't edit profiles my formatting toolbar is also missing
thanks in advance.
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : february1 | author: ECWebsites | version: | creationdate: 2011-02-23
Modules: Kunena Latest: Disabled or not installed | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
15 years 6 months ago #94222 by thetoast
Replied by thetoast on topic Re: Can't edit profile
This is not the section to request support for Kunena. it is clearly stated in the Description of the section "Please use other categories for support questions."
The correct section would be K 1.6 Support
I'm sure someone will move this to the right section.
Can't tell exactly what the problem is by looking at your Config report.
I going to go out on a limb and say that you have some type to JS (Javascript) error or template error going on that is conflicting with mootools.
15 years 6 months ago #94235 by sozzled
*** Topics merged ***
G'day, Domino, and welcome to Kunena.
Please read msg #1 in this topic.
15 years 6 months ago - 15 years 6 months ago #94291 by treybraid
using joomla 1.5.22 and kunena 1.6.3 on a local install... when i create an account to access the forum--if i click on profile tab i am unable to edit it... nothing is there when i choose edit... and the tabs dont work either am i missing something... module or plugin that also needs to be installed...
are there certain settings i need to enable so the profile can be editted...first time using kunene...
thanks
trey
Last edit: 15 years 6 months ago by treybraid.
15 years 6 months ago #94293 by cocali
Replied by cocali on topic System - Mootools Upgrade
I'm using Kunena 1.6.2 and Rapid Receipes.
Because System - Mootools Upgrade is in conflict with rapid receipes component, i want to desactivate this plugin.
Kunena gave me the following message:
* Kunena: You have a plug-in that uses MooTools 1.1 or a custom version of JHTMLBehavior.
* Many features, including Quick Reply and the BBCode editor, may be broken.
* Please enable the System - MooTools Upgrade plug-in.
Please HELP. Can I use Kunena 1.6.2 without System - Mootools Upgrade ???
Time to create page: 0.159 seconds
