15 years 7 months ago #93175 by sozzled
  • C0n
  • C0n's Avatar
  • Offline
  • Premium Member
  • Premium Member
  • Only the strongest will survive
15 years 7 months ago - 15 years 7 months ago #93181 by C0n
Do you have a download link to mootools or mtupgrade ? Neither of them are instaled on my site. And i cant find a download link for mootools in the kunena docs..?
Last edit: 15 years 7 months ago by C0n.
15 years 7 months ago #93185 by sozzled
The answers to those questions are contained in the links posted at the end of msg #1 in this topic. Mootools 1.2.4 is included as a standard feature of all versions of Joomla after J! 1.5.19.
  • C0n
  • C0n's Avatar
  • Offline
  • Premium Member
  • Premium Member
15 years 7 months ago #93201 by C0n
Ive downloaded it now :D everything is working fine thanks sozzled <3
15 years 7 months ago - 15 years 7 months ago #93219 by mmafight
Replied by mmafight on topic cant edit user profiles
i just installed kunena 1.6.3 forum at my site www.mmafight.gr and everything works fine BUT i cant edit my user profile. I can click edit but the forms are not visible so i cant add my info, add avatar etc.
htaccess: Exists | PHP environment: Max execution time: 1100 seconds | Max execution memory: 128M | Max file upload: 200M
Joomla default template details : cloudbase | author: CloudAccess.net | version: 1.0.14 | creationdate: 21 March 2011
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Enabled (Version : 1.6.0-RC1)
EDIT: and NO the 1st msg didnt help me at all
EDIT2: I tried to change the template, disabled all modules and checked my plugins directory but it only worked when i disabled myapi facebook plugins... then i could edit the profile. But, after that i enabled my api plugins again and it still worked! dont know why...
Last edit: 15 years 7 months ago by mmafight.
15 years 6 months ago #93515 by Adi_VCF
Replied by Adi_VCF on topic The problem with bbcode-om
Hello everyone, I hope to find a solution here that I have my problem with Kunena 1.6.3.
In fact, I can not put any smilies in the text, because the bar below the smilies writes bbcode help-type can be used in selected text.
I tried a variety of ways to fix, but no go.
I asked for a solution to the net, but I have not found anything.
BB code to me in the Kunene running but not showing me any smilies or tape in which has to be code for the video, font color, etc.
I would ask if anyone has a solution that can help me he was very grateful.
PS It should be noted that I migrated from an older version of Kunene, and for connecting the forum and Joomla use Joomsocial.
Here in this picture you can see how it looks.
http://img706.imageshack.us/i/unled1ok.gif/
Time to create page: 0.178 seconds
