15 years 4 months ago - 15 years 4 months ago #94291
by treybraid
Replied by treybraid on topic unable to edit profile at all... none of the tabs even work
using joomla 1.5.22 and kunena 1.6.3 on a local install... when i create an account to access the forum--if i click on profile tab i am unable to edit it... nothing is there when i choose edit... and the tabs dont work either am i missing something... module or plugin that also needs to be installed...
are there certain settings i need to enable so the profile can be editted...first time using kunene...
thanks
trey
thanks
trey
Last edit: 15 years 4 months ago by treybraid.
15 years 4 months ago #94293
by cocali
Replied by cocali on topic System - Mootools Upgrade
I'm using Kunena 1.6.2 and Rapid Receipes.
Because System - Mootools Upgrade is in conflict with rapid receipes component, i want to desactivate this plugin.
Kunena gave me the following message:
* Kunena: You have a plug-in that uses MooTools 1.1 or a custom version of JHTMLBehavior.
* Many features, including Quick Reply and the BBCode editor, may be broken.
* Please enable the System - MooTools Upgrade plug-in.
Please HELP. Can I use Kunena 1.6.2 without System - Mootools Upgrade ???
15 years 4 months ago #94295
by 810
Replied by 810 on topic Re: System - Mootools Upgrade
No, you must enable mootools upgrade. also please update to kunena 1.6.4
regards 810
regards 810
15 years 4 months ago #94301
by 810
Replied by 810 on topic Re: unable to edit profile at all... none of the tabs even work
Please enable Mootools upgrade plugin.
regards 810
regards 810
15 years 4 months ago #94307
by treybraid
Replied by treybraid on topic Re: unable to edit profile at all... none of the tabs even work
that blows out about 3 installed modules... any other options available...
trey
trey
15 years 4 months ago #94308
by treybraid
that dsnt do a thing...
trey
trey
Time to create page: 0.299 seconds
