Question Templates for Kunena 1.7 ?
15 years 1 month ago #106601 by snilloconator
I have most of my sites running K1.7/j1.5.23 and installed the aphotic templates with no problem. May I ask is it a particular template your trying to install?
15 years 1 month ago #106617 by umersaeed
I have tried 3 different templates from templatekunena website:
A1
Gainsboro
B&B ( www.kunena.org/ked/templates/76 )
Still nothing? I have turned Debug mode off (incase that caused any problems).
Anything in the backend settings that may cause this?
15 years 1 month ago #106641 by snilloconator
By any chance can you try one of the two here..... >>> www.snilloconator.com/downloads
Just for testing purposes. Maybe we can help you weed out the issue, at least see if it will load one of the two. I have tried both with no problems so far.
15 years 1 month ago #106682 by umersaeed
OK, So I have tried both of those Aphotic ones, and they installed perfectly without any issues! (I guess as they mentioned that they are compatible with K1.7).
I gave the other ones a go again just incase, but they others still dont work - still get that template.xml error. Not sure how you are able to and I am not...so it cant be due to K1.6 or K1.7 compatibility then?
15 years 1 month ago - 15 years 1 month ago #106684 by snilloconator
Well I did not have to change anything in my xml file so that the templates would play nice. The only thing I can think of is that this may be an original problem with the particular template(s) you mentioned. Did these work on other or older test beds?
Also can you add the template zip file here. I'll take a look.
Last edit: 15 years 1 month ago by snilloconator.
15 years 1 month ago #106685 by umersaeed
Not sure if this may help trying to find solution, but my "Section Collapse" doesnt work either on the forum?
When I click that little arrow to collapse one category section, nothing happens?
