Question Templates for Kunena 1.7 ?
15 years 1 month ago - 15 years 1 month ago #106720 by @quila
@umersaeed
Gainsboro template was never designed to be used with Kunena 1.6+. This template is ONLY for Kunena 1.5 and cannot be installed on other version of Kunena. So it is normal that you have this error when you try to install it on Kunena 1.7.
Light template you have attached in this topic cannot be installed on kunena from this package. I dont know nothing about this template but what I see from zip you attached you must unzip this file first. Then inside you will find other zip package light.zip and you can install this one.
@Nihil
from error you reported looks like you are trying to install Kunena Template Aphotic2 using JOOMLA Installer and this is not possible. Try to use Kunena Template Manager to install this template.
Hope this helps.
Regards
Last edit: 15 years 1 month ago by @quila.
15 years 1 month ago #106722 by umersaeed
I guess there isnt that many K1.7 compatible templates out there then?
15 years 1 month ago #106723 by @quila
All templates from Extensions directory which are taged for Kunena 1.6.x are compatible, can be installed and used with Kunena 1.7.0. If template is not updated for Kunena 1.7.0 that mean that you will miss some feature form newest version of Kunena. But template should run without errors.
15 years 1 month ago - 15 years 1 month ago #106724 by xillibit
Nihil wrote:
File Attachment:
File Name: aphotic-II.zip
File Size:379.61 KB
Here is the link i used. Here is the link i used.
This is the exact error:
JInstaller: :Install: Cannot find Joomla XML setup file
Aphotic (1) works fine aside from it not showing the kunena tabs.
I don't encounter any issues with that ^
Last edit: 15 years 1 month ago by xillibit.
  • Nihil
  • Nihil's Avatar
  • New Member
  • New Member
15 years 1 month ago #106725 by Nihil
Replied by Nihil on topic Re: Templates for Kunena 1.7 ?
@quila,
Gah! That did it! Thanks. i try to keep that in mind if i try to change the template again.
Aphotic 2 is working and looks great.
Snillo,
When i used Aphotic and now Aphotic 2, the Kunena tabs disappeared. How do i get them back?
15 years 1 month ago #106980 by snilloconator
Is this still a problem for you? I haven't experienced this and would like to see. TY
