Question Templates for Kunena 1.7 ?
15 years 1 month ago #106686 by umersaeed
This is the first time I am using Kunena, so naturally, the first version I ever got was K1.7.
I havent used K1.6 before so I couldnt test the templates with that version.
15 years 1 month ago #106687 by snilloconator
That is another issue, more than likely mootools is not enabled or conflict with your joomla theme.
  • Nihil
  • Nihil's Avatar
  • New Member
  • New Member
15 years 1 month ago #106691 by Nihil
Replied by Nihil on topic Re: Templates for Kunena 1.7 ?
i recently tried to install Aphotic 2 into a J 1.6.6 + Kunena 1.7 site and it says it couldn't find the XML install file. Did i use the wrong version of the template?
15 years 1 month ago #106692 by umersaeed
I dont know if this is a cause of all this, but I am also having all of these errors as well:
Read this Kunena Mootools Thread
Mootools conflicts!! I HATE MOOTOOLS!!!
15 years 1 month ago #106696 by xillibit
I hate things which still use Mootools 1.1 instead of 1.2 or 1.3
Can-you check the template package if the xml file is in there ?
15 years 1 month ago #106698 by umersaeed
Its quite strange, because all the template files have the respective template.xml files in there, but when uploading through template manager, it says that it cannot be found??
