Sticky How to move, copy or merge my old Kunena forums from one site to another
As a start, I suggest you look at msgs #4 and #6 of the topic [Merged topic] How to move my Kunena forum from one site to another . Yes, this topic was written when older versions of Joomla were commonplace and, yes, the information relates to an older version of Kunena, but the principles are basically the same.
You need to copy the Kunena database tables, the Joomla user tables (assuming you are going from the same major versions of Joomla on one site to the other site) and you need to copy the attachments. The difficulty is going to be whether the Joomla user tables in J! 2.5 will be similar to J! 3.0 (and I have not researched this information). That's something you should ask at the Joomla forum ( forum.joomla.org ).
These three things - Kunena data, Joomla users and forum attachments - are the three areas you need to look at.
Advising users of the detailed steps they must follow in moving Kunena from one site to another is not the "core business" of this forum - the main focus here is to help people setup, manage and run Kunena on the site where they have installed it - and it's a little "off-topic" to the central purpose for which this site exists. That is why I have moved this topic to the Miscellaneous, off-topic and general Joomla category in the hope that other members of the community, who may have been through the same process, may be able to offer their insights.
The task of copying site features (from one site to another) requires careful planning. The issues involving moving components from one site (running a specific version of Joomla) to another site (running a different version of Joomla) are beyond the scope of this forum. Those are matters best dealt with by the Joomla forum .
I hope this information helps a little.
Perhaps another member of the community has more information that they might care to volunteer.
I can only speak in relation to matters involving Kunena.
- MikeFromHC
- Thank you received: 2
I have been forced to use version 3.0 on my website and link to it from my clients website (Godaddy has been promising to update for over a year)
It works but at some point I will want to import version 3.x tables from my site to my clients.
I have been unable to find information on what tables I need to move.
I merged your topic with another topic where similar questions were asked.
I think you will find that many of these "abandoned" topics are like that because people ask the "question", we give the information, and people do not respond by telling the community if the information gave them the answer.MikeFromHC wrote: I've found several articles that deal with importing other forums into Kunenu but they all seem essentially abandoned.
It's a bit like the question you asked a few days about about " how to change the "default view" of the forum from 'Recent Topics' to 'Index' ". We answered your question but you have not replied to let the community know if the information helped you.
It's quite straightforward to copy a website from one webhost to a different webhost (as long as you're not making any changes) and to carry on operations in the new webhost in the same fashion as things worked before. Using a tool like Akeeba Backup will achieve this very quickly.MikeFromHC wrote: I have been forced to use version 3.0 on my website and link to it from my clients website (Godaddy has been promising to update for over a year)
I am not sure how you have been forced to use "version 3" in your case - "version 3" of what? Joomla or Kunena? - and this complicates the situation. Are you constrained to use "version 3" because of the webhost or because of the requirements of your client?
Msg #4 of this topic outlines the things you need to move. Moving a forum from one place to another is not just a matter of copying a 20-30 database tables. There are three things that you need to move across:MikeFromHC wrote: I have been unable to find information on what tables I need to move.
- Kunena data (tables);
- Joomla users; and
- forum attachments
Moving from K 2.0 on one version of Joomla to a different version of Joomla is complicated because it's not a simple matter of copying database tables when the table structures are different. Moving the forum, in this case, involves migrating Joomla from one version to a version that allows you to upgrade to K 3.0.
So you have to look at an alternative plan and, because we don't know what versions of Joomla or Kunena you were using on your GoDaddy platform, it's my guess that you need to move the existing site from GoDaddy to another place and then do this migration in the new environment. It's a complicated process and it will probably take you a couple of days to plan things and execute your plan.
The tips in this topic should be able to guide you through the process.
- YonisHobby
- Junior Member
1. Update my old site to the latest Joomla 2.5
2. Upgraded Kunena to the latest 3
3. Installed the same Kunena 3 on my new Joomla 3 site
4. Dropped all Kunnena tables on the new site
5. Export all Kunena tables on the old site and import them to the new one
The issue is that I couldn't migrate the users. Importing the tables left the site inaccessible. Creating new users and changing there IDs will not let them log in.
Very problematic not having a straight path for Upgrade / Migrate of the forum.
This is precisely what I was trying to say earlier in this topic:YonisHobby wrote: The issue is that I couldn't migrate the users. Importing the tables left the site inaccessible. Creating new users and changing there IDs will not let them log in.
sozzled wrote: The difficulty is going to be whether the Joomla user tables in J! 2.5 will be similar to J! 3.0 (and I have not researched this information). That's something you should ask at the Joomla forum ( forum.joomla.org ).
From the sounds of things, it's not a straightforward case of exporting the J! 2.0 user tables to a J! 3.1 website at least, not unless your old J! 2.0 site is migrated to J! 3.1 beforehand. What you have written confirms my suspicions.
If you cannot use your "old" users in your new site then you can't use your old forum in your new site. I repeat what I wrote earlier in this topic:
sozzled wrote: There are three things that you need to move across:
- Joomla users; and
- forum attachments
When you attend to those three things you will be able to use your old forum on your new site.
- Ace kustoms
Both are using 3.01 kunena
Both are using Joomla 2.5.11
