Before posting new topics in this category K 1.5.x Support: Please read this first.
Question Email problems with categories set Review = Yes
16 years 3 months ago - 16 years 2 months ago #58161 by MGSMKS
I am fairly new to Kunena and I am not a techie. I have a few issues and would appreciate your help. I have the 1.5.4 version.
I've set up the forum with several categories and each category has a sub-category. The category posts are not pre-moderated, but the subcategory posts are pre-moderated. When I test, this is what happens:
(1) When I post in a non-pre-moderated category, I get a "cannot initialize the send function" (screen-shot attached although it is in Russian) yet the posting appears fine without a problem. However, I have it set to receive a note about the new posting as the moderator, but I receive nothing.
(2) When I post in a pre-moderated sub-category, I don't receive anything to alert me that there is a post waiting to be moderated (I am using a test account to post). I only see that there is a new post waiting to be moderated when I log into the forum and go to that sub-category. I set it up to receive notifications by e-mail (at least I think I did). Or am I doing something wrong here?
Thank you.
Last edit: 16 years 2 months ago by sozzled. Reason: Changed subject to improve the relevance in searching
16 years 3 months ago #58165 by Cerberus
upgrade to latest version K1.5.12 as there have been 100s of fixes since K1.5.4
16 years 3 months ago #58170 by MGSMKS
Thank you for your reply. How do I upgrade? Is there a tutorial on how to do it? Appreciate your help.
16 years 3 months ago #58172 by xillibit
You just need to install kunena 1.5.12, but backup your template and others things
You cna take a look at the doc : docs.kunena.com/index.php/Upgrade_Information_V1.5
16 years 3 months ago #58176 by MGSMKS
This looks really complicated. :( Can I just uninstall the old version and install the new one?
16 years 3 months ago - 16 years 3 months ago #58178 by Cerberus
Cerbs simple step to upgrading K1.5x to K1.5.12
1. Backup your site and database
2. Download latest version of kunena from Here
3. Go to joomla installer and install
4. Check every thing is working
FYI: no need to uninstall old version its all done for you
Last edit: 16 years 3 months ago by Cerberus.
