Kunena 7.0.8 Released
Idea How to change Karma position?
16 years 1 month ago - 16 years 1 month ago #53322 by sozzled
You might try editing view.php (don't know what line number) for the code that generates
<td class="fb-msgview-left-b">&nbsp;</td>
and change it to
<td class="fb-msgview-left-b" colspan="2">&nbsp;</td>
That will, at least, tidy things up a little bit.
EDIT: I think @quila has a fairly good handle on this problem and my suggestion may not be necessary.
Last edit: 16 years 1 month ago by sozzled.
16 years 1 month ago - 16 years 1 month ago #53324 by iLucato
@quila wrote: You have placed that code in wrong place. Place the code AFTER <tr> and BEFORE <td class = "fb-msgview-right-b" > like I said before
<tr>HERE<td class = "fb-msgview-right-b" >
<div class="fb_message_editMarkUp_cover">
you have placed code AFTER <td class = "fb-msgview-right-b" >
Ops, my fault! Didn't make too much difference. :0) Here is the result I get as logged-in and as visitor by using the corret way you requested as show below:
<tr> <td align = "right"> <span class = "msgkarma"> <?php if (isset($msg_karma)) { echo $msg_karma; if (isset($msg_karmaplus)) echo '&nbsp;&nbsp;' . $msg_karmaplus . ' ' . $msg_karmaminus; } else { echo '&nbsp;'; } ?> </span> </td> <td class = "fb-msgview-right-b" > <div class="fb_message_editMarkUp_cover">
Here is the screenshot to you have an idea.
@quila, I'm not programmer and you are the man, but in my humble opinion, I think it should go somewhere around the "fb_message_buttons_row" arround line 420 and ahead, shouldn it in this case?
I'll try the Sozzled stuffs and will be back. :0)
Last edit: 16 years 1 month ago by iLucato.
16 years 1 month ago #53331 by @quila
OK, replace your message.php with this attached and say me what you see.
File Attachment:
File Name: message.zip
File Size:4.38 KB
16 years 1 month ago #53333 by @quila
Or you can leave this where xyou have now (below profile), maybe is better place
16 years 1 month ago #53336 by iLucato
There you go! Amazing! Thanks a lot! Now, what have you changed? I think I have some custom stuffs changed and I can't use your file, well if it is hard I'll try to compare the files.
Just one question regarding this karma. Is the karma about the thread/post or for the user? I mean, members vot for rating the specific post or the user?
16 years 1 month ago #53339 by @quila
For changes look the line 79 and between 347 - 362.
Karma is related to user.
Time to create page: 0.254 seconds
