Kunena 7.0.8 Released
Idea How to change Karma position?
16 years 1 month ago - 16 years 1 month ago #53340
by iLucato
Thanks for your kind help folks. I appreciated that. Have a nice day.
Replied by iLucato on topic Re: How to change Karma position?
I see. Thanks a lot! I got to identify it.@quila wrote: For changes look the line 79 and between 347 - 362.
Ops, I didn't know that. Please, don't punch me, but IMHO it should fit better into the grayed user column than instead of where I had asked. :0( I mean, it would be more logical. Well, I'll try to put there, if I don't get it will remain there. :0)@quila wrote: Karma is related to user.
Last edit: 16 years 1 month ago by iLucato.
16 years 1 month ago #53347
by iLucato
Hey folks, after some changes, here what I got once the karma is related to the user. ;0)
For who may be interested here is how it was done:
For my layout I had to change into the kunena.forum.css the padding-right value for the span.msgkarma, so it looks this way around the line 777:
Now to move the karma below the avatar, the code is placed next the line 225 next to the class 'viewcover' and the margins values were changed.
Here is the code surrounding the line 220 that you need to find...
right after that you place the karma code:
Don't forget to remove the previous code like that nearby the lines 78-94.
#Kunena span.msgkarma {
font-weight: bold;
color: #333333;
text-decoration: none;
padding-right: 50px;
white-space: nowrap;
float: left;
<span class = "view-group_<?php echo $gr_title->id;?>"> <?php echo $gr_title->title; ?></span>
<?php
<span class = "msgkarma" style="float: left!important; margin:0px 0 5pt 20px;">
<?php
if (isset($msg_karma)) {
echo $msg_karma;
if (isset($msg_karmaplus))
echo ' ' . $msg_karmaplus . ' ' . $msg_karmaminus;
else {
echo ' ';
</span>
16 years 1 month ago - 16 years 1 month ago #53348
by @quila
Replied by @quila on topic Re: How to change Karma position?
Great, thanks for share.
BTW: One question, I see you forum is new, is there some reason why you dont install Kunena 1.6?
All this personalisation you will lost when you upgrade to K1.6 (and karma is already there in K1.6), you could have much more function and Template you can easly customised .K1.6 is software with future, at some point K1.5 will stop to develop.
Last edit: 16 years 1 month ago by @quila.
16 years 1 month ago - 16 years 1 month ago #53411
Replied by sozzled on topic Re: How to change Karma position?
Moderator's comment: further discussion that started from this thread has been moved to
Where can I obtain the download for K 1.6
. Please try to keep discussions on-topic.
Last edit: 16 years 1 month ago by sozzled. Reason: Explain reason for topic split
Time to create page: 0.264 seconds
