Idea How to change Karma position?
16 years 4 months ago - 16 years 4 months ago #53288 by iLucato
Hi folks,
I'm using the K 1.5.12 and the issue is that the thread title runs over the karma on the right side. See the circled area in red on the right top of the thread at the image below:
So, I want to place it on the very left at the bottom (Green circled area) on the same line as the message "This thread was closed", well the image is in Portuguese-BR where you can read "O tópico foi fechado." on the right bottom of the thread (circled in red)
So, I wonder what is the filename that I can find and change the karma code position to place it where I want too (green circled area).
Thanks in advance.
Last edit: 16 years 4 months ago by iLucato.
16 years 4 months ago #53314 by @quila
Hi iLucato,
to do that you need to make changes in message.php
components / com_kunena / template / default_ex / message.php
About line 78 you will see that code
<td align = "right"> <span class = "msgkarma"> <?php if (isset($msg_karma)) { echo $msg_karma; if (isset($msg_karmaplus)) echo '&nbsp;&nbsp;' . $msg_karmaplus . '&nbsp;' . $msg_karmaminus; } else { echo '&nbsp;'; } ?> </span> </td>
move it down in about line 329
<tr>HERE<td class = "fb-msgview-right-b" >
<div class="fb_message_editMarkUp_cover">
Regards
16 years 4 months ago #53317 by iLucato
Hi @quila, thanks a lot for your tip!
Man, I placed the code where you've suggested (around line 343) as you can see here:
<td class = "fb-msgview-right-b" > <td align = "right"> <span class = "msgkarma"> <?php if (isset($msg_karma)) { echo $msg_karma; if (isset($msg_karmaplus)) echo '&nbsp;&nbsp;' . $msg_karmaplus . ' ' . $msg_karmaminus; } else { echo '&nbsp;'; } ?> </span> </td> <div class="fb_message_editMarkUp_cover">
and I got it:
Now I need to try the tds, trs, divs, by guessing once I have no idea how they work, to see if I get a better fit. If you have a better idea, I'll appreciate again your kind help.
Thanks and have a nice day.
16 years 4 months ago - 16 years 4 months ago #53319 by sozzled
You'll need to experiment with the CSS to position the Karma indicator in a TD with a border, padding, etc. Looks like you've got your work cut out for you.
Last edit: 16 years 4 months ago by sozzled.
16 years 4 months ago - 16 years 4 months ago #53320 by iLucato
I did it, and didn't solve. I mean, I changed the span.karma in the CSS
16 years 4 months ago #53321 by @quila
You have placed that code in wrong place. Place the code AFTER <tr> and BEFORE <td class = "fb-msgview-right-b" > like I said before
you have placed code AFTER <td class = "fb-msgview-right-b" >
