Question sync users failure - error 1146 and SQL error
Do you have solved the issue that you have explained in the first post of this thread ?
Have not fixed the problem that began this thread yet. I could not get the down time to work on the problem until now.
As I understand it, un-installing and re-installing the Kunena component is what must be done to fix it.
I have found templates in a couple of other locations:
$HOME/www/components/com_kunena/template/(default, default_ex, default_gray, default_green, default_red, zephyricons)
and the same directories in $HOME/public_html
I see in Kunena Configuration references to these templates (only):
default_gray
zephyricons
Would I just un-install default_gray and zephyricons before the Kunena un-install/re-install? If so, are they installed again when I re-install Kunena? Do I need to save off the current ones some place and then copy them in again after Kunena has been installed?
By the way I found that I have to use Kunena v1.0.11 because of the php release level at my hoster.
Thanks,
Rob
Thanks for the info. I've asked at my host about their upgrade plans and they've been silent for 24 hours so far. We may not be able to move right away and the fact is I need to upgrade Kunena in order to fix the issues I've described at the beginning of this thread. While it might not be possible to upgrade to the latest release, if it fixes the problem causing pain then perhaps it may be worth considering.
Thanks for your input and will make sure that a move to an upgraded PHP is part of our planning.
Rob Cohen
The code can be adapted to K1.0, but it's not trivial. If you want me to do this as paid job, Skype me: matias.griese
But if your hosting company wants to make money for free -- I'd advice you to vote with your legs and try to find better hosting for your needs.
