Question [Merged topic] Preview does not work
  • cXc
  • cXc's Avatar
  • New Member
  • New Member
17 years 2 months ago #28153 by cXc
Thanks for the info @quila I'll give it a try :dry:
I probably should have mentioned I don't have this problem with FB only with Kunena. The FB forum on my site has working preview button. There are no problems with bbCode at all and all work correctly it is only with the preview button.
Anyone know what changes have been made to the preview button since FB 1.0.5?
~cXc~
17 years 2 months ago #28154 by xillibit
greg wrote:
I too can not get the editor to work. bold, italic,stike thru, work
color change, size change , the tip in spoiler doesnt show.
The preview also does nothing at all.
Is it a conflict with Joomla editor? I am using Jomsocial 1.1.145
Joomla 1.5.11
thank you in advance for your help
Greg
There is a fix for this here : www.kunena.com/forum/139-solved-or-prior...-working-in-155#2665
  • cXc
  • cXc's Avatar
  • New Member
  • New Member
17 years 2 months ago #28155 by cXc
If it matters I tried that fix just in case the issue was related but it did the same thing with or without that fix.
17 years 2 months ago #28182 by greg
Joomla 1.5.11
Greg
Thank you this solved the problem now my last issue is getting images to show in the post. some times what showes is only the url???
her is a pic of my dogs
17 years 2 months ago - 17 years 2 months ago #28189 by greg
I think the problem is I can not post more than one image in a thread. I started a thread and was able to post one image in the next post there was not the ability to post. I will try and post another image here.
Last edit: 17 years 2 months ago by greg.
  • cXc
  • cXc's Avatar
  • New Member
  • New Member
17 years 2 months ago - 17 years 2 months ago #28193 by cXc
@greg
Give this thread a look and see if it solves your other problem ;)
www.kunena.com/forum/138-support/27167-i...to-kunena-155-proper
~cXc~
Last edit: 17 years 2 months ago by cXc.
