Question [Merged topic] Preview does not work
and even my signature doesnt display?
any one please help.
www.footballfuror.com
check this thread, it can help you : www.kunena.com/forum/135-solved-or-prior...ply-and-pm-dont-work
- cXc
When I click on the preview button it shows the loading gif for a moment then the page goes white. I can leave the page open for hours but it never loads, just stays blank with the loading gif running in the tab bar.
Joomla! 1.5.14
Kunena 1.5.5
No Modules on page except for menu, RT Akiraka template using moomenu but that shouldn't matter it doesn't load when I use no navigation and load only the forum with no menu either.
The white pages html is ...
Since it starts to load I'm assuming its somewhere in the JS but I'm not very good with JS, any help on this would be great its the only thing keeping me from switching over from Fireboard.
Thanks,
~cXc~
you can start to disable this plugin one by one docs.kunena.com/index.php/Conflicting_plugins
Regards
color change, size change , the tip in spoiler doesnt show.
The preview also does nothing at all.
Is it a conflict with Joomla editor? I am using Jomsocial 1.1.145
Joomla 1.5.11
thank you in advance for your help
Greg
