- Thank you received: 565
Question [Merged topic] Preview does not work
Odd.. I've got this message during installation, too, but not with Kunena.
About your other issues: preview is not huge issue (maybe you can just remove the button), but editing.. Hmmm. Is it browser specific issue?
So, one down, one to go:
About the Apache-log, this place is empty:
/domains/groengeel.nl/public_html/logs. But I found this one:
/domains/groengeel.nl/logs with this log-file [file/]
it doesn't say 'fatal' anywhere, but is it bad?
thanx for your help,
Birdy
And you should look into log file just after you have triggered error in your site (makes it easier to find problems).
Please zip your file or it won't get added (hmm.. does it warn about it?)
You can also attach text into messages. Just add spoiler tag around it to hide it by default.
I have two files; this groengeel.nl.error.log (2Mb) file attached below and groengeel.nl.log (26 Mb), I tought I'll only post the 2Mb file;
[strike]Deleted[/strike]
The log-files are only created once a day, around 0.05, can I change that?
Try default_ex instead of default_green: it may fix the problem.. I'm not finding any error messages, so the template may just be broken (it's kind of legacy feature and deprecated).
A different template doesn't make any difference, but I'll keep on trying to find the solution.
thanx,
Birdy
