Question [SOLVED]Confused: Is K153 Native or not? I had to enable system/legacy for K153 to work.
16 years 11 months ago #20551 by DigitalPriest
I did not delete, I just went there and selected kunena forum again. Should I go there, dlete the menu item, and create it again?
Yes, I have sh404sef and it works fine.
DP/ND
16 years 11 months ago - 16 years 11 months ago #20552 by Lintzy
if you set it again, then no. You built it new quasi. Please try to disable SEF 404, empty cache, if this works.
Last edit: 16 years 11 months ago by Lintzy.
16 years 11 months ago - 16 years 11 months ago #20556 by DigitalPriest
:S
well, I just had 5 minutes of horror...
Whole site went down with the message "direct acess ..." after I emptied the sef url table, and disabled the legacy plugin.
It seems that sh404SEF works fine with or without legacy plugin, BUT it can not add new urls to database without legacy turned on! Problem that I thought that Kunena is strange, was in fact problem with sh404sef because I disabled legacy, added new kunenea which obviously had some new links which had to be added to database and sh404 made that "direct access" message when I clicked on kunena link which was only new link - not in sh404's database... So, I tought it's kunena, but it is not, the problem is sh404sef - because of sh404sef, I must keep legacy plugin enabled.
Thanks 4 help, You are great, really.
:cheer:
DP/ND
Last edit: 16 years 11 months ago by DigitalPriest.
16 years 11 months ago #20563 by Lintzy
You are welcome :)
DigitalPriest wrote:
:S
That is ONE reason, why I am using "only" the integrated optional SEF from Joomla. I have seen so much issues with SEF extensions, so that I decided to use solely Joomla SEF.
16 years 11 months ago #20564 by fxstein
It is very unfortunate, but we have seen 60%+ of problems reported here come from 3rd party SEF tools.
We don't want to diminish the work of other developers, but there is a very solid SEF option built into Joomla 1.5 itself.
It works, does not need memory and CPU hungry caches and the site simply works with it.
Might consider that for your own site.
16 years 11 months ago #20657 by johnnydement
Yep, core sef function is pretty solid, could be more customizable? sure, those numbers there are not nice enought, but the URL's are pretty readable, and does not comsume extra CPU...
Time to create page: 0.321 seconds
