Question [SOLVED]Confused: Is K153 Native or not? I had to enable system/legacy for K153 to work.
16 years 11 months ago - 16 years 11 months ago #20526 by DigitalPriest
When legacy is not ON then I get standard message "direct access..." (on J1.5.10)
Will that be fixed in some future versions ?
Beside that legacy "issue", I had no problem whatsoever with transition from 109 to 153..
Great work, guys! Thanks.
DP/ND
Last edit: 16 years 11 months ago by DigitalPriest.
16 years 11 months ago #20530 by Lintzy
Kunena 1.5.3 is final and native. Do you have Community Builder installed, too?
16 years 11 months ago #20531 by xillibit
Kunena 1.5.3 works natively on Joomla! 1.5.x without enabled the plugin legacy like explained here : docs.kunena.com/index.php/Kunena_1.5.3_Read_Me .
You problem doesn't come from the legacy, where this message is displayed, in recent discussions, in categories ?
16 years 11 months ago - 16 years 11 months ago #20548 by DigitalPriest
I did it again, twice, just to be absolutely sure:
When I disable system/legacy plugin, in main menu - when I click on FORUM link in main menu I get a complete white page which says: "Direct Access to this location is not allowed". When I enable legacy plugin, forum works normally.
I Have no Community builder installed.
You can see the forum
forum on lidder site
which works only when legacy plugin enabled?
It does not make me any problem for now, but it is strange...
During the install process, i had legacy plugin disabled, as I expected K153 to be native, and everything went well.
thanks for responding,
DP/ND
16 years 11 months ago #20549 by Lintzy
Did you delete the Navigation Point Forum in navigation menu and set it again/new? You should do so.
Any SEF plugins installed?
16 years 11 months ago #20550 by fxstein
You either have another plugin, module or extension installed or you are using a template that is not 1.5 native.
Kunena 1.5.3 is fully native and will not create a message like that by itself.
Please make sure you are not using an outdated template and that any modules you have installed are 1.5 native as well.
Hope this helps!
fxstein
Time to create page: 0.242 seconds
