Question [SOLVED]Confused: Is K153 Native or not? I had to enable system/legacy for K153 to work.
- DigitalPriest
Will that be fixed in some future versions ?
Beside that legacy "issue", I had no problem whatsoever with transition from 109 to 153..
Great work, guys! Thanks.
DP/ND
Kunena 1.5.3 works natively on Joomla! 1.5.x without enabled the plugin legacy like explained here : docs.kunena.com/index.php/Kunena_1.5.3_Read_Me .
You problem doesn't come from the legacy, where this message is displayed, in recent discussions, in categories ?
- DigitalPriest
I did it again, twice, just to be absolutely sure:
When I disable system/legacy plugin, in main menu - when I click on FORUM link in main menu I get a complete white page which says: "Direct Access to this location is not allowed". When I enable legacy plugin, forum works normally.
I Have no Community builder installed.
You can see the forum
forum on lidder site
which works only when legacy plugin enabled?
It does not make me any problem for now, but it is strange...
During the install process, i had legacy plugin disabled, as I expected K153 to be native, and everything went well.
thanks for responding,
DP/ND
Any SEF plugins installed?
You either have another plugin, module or extension installed or you are using a template that is not 1.5 native.
Kunena 1.5.3 is fully native and will not create a message like that by itself.
Please make sure you are not using an outdated template and that any modules you have installed are 1.5 native as well.
Hope this helps!
fxstein
