Kunena 7.0.8 Released
Question How to assign a moderator to my Kunena forum
16 years 1 month ago #55182 by sozzled
b0n40 wrote: But still i cant make my users moderators
There are at lest two ways that I could interpret this statement:
(1) When you use the User Administration facility, and you select a user to assign as a moderator, when you set Is Moderator = Yes (and save the change) the setting is not applied. That's one possible reading of the question. In other words, are you saying that there is a problem with the procedure that assigns a moderator?
(2) The procedure of setting a moderator works but the users you have assigned to moderate your forum (or specific categories in your forum) do not have moderator privileges. Is this what you are asking? In this case, look again at the forum categories and verify that your categories are set Moderated = Yes.
I think we need to understand what is the specific problem here. I don't understand how the Synchronize Users facility has become involved in this discussion. :dry:
There may be other problems that you may want to ask us about, but for the benefit of other people, can we please remain focussed on this one. How to assign a moderator to your forum. What I'm trying to do is answer that question and to explain the process. If we're agreed that the process is correct, then that's where the thread should stop. If you're having a problem with the process that's probably a new topic.
16 years 1 month ago - 16 years 1 month ago #55189 by b0n40
sozzled wrote: (1) When you use the User Administration facility, and you select a user to assign as a moderator, when you set Is Moderator = Yes (and save the change) the setting is not applied. That's one possible reading of the question. In other words, are you saying that there is a problem with the procedure that assigns a moderator?
Exactly my problem. I posted in this one, cos i need it to be sure im not doing something wrong.:unsure:
I will open a new topic. Link
sozzled, again Thanks for ur help :)
Last edit: 16 years 1 month ago by b0n40.
Time to create page: 0.206 seconds
