Kunena 7.0.8 Released
Question How to assign a moderator to my Kunena forum
16 years 4 months ago #45475 by Mick
The way Cerberus said it was done was perfect.
16 years 4 months ago - 16 years 4 months ago #45477 by sozzled
Cerberus wrote:
in admin sectio of kunena go to USER MANAGER then select the user you want to make a mod and then change there RANK setting to MODERATOR :) and your done..
So, all you need to do is assign the rank of moderator, and your user has all the moderator privileges? Is that what you are saying? And you've checked this for yourself? :blink:
Last edit: 16 years 4 months ago by sozzled.
16 years 4 months ago #45478 by Cerberus
16 years 4 months ago #45479 by sozzled
I tried it, twice, didn't work. Sorry. Assigning the rank of moderator to an "ordinary" user does not give them any moderator privileges. I'll check again, but I'm pretty sure I'm right. :S
16 years 4 months ago - 16 years 4 months ago #45480 by sozzled
Sorry, nope. K 1.5.11 - assign rank of moderator to a user does not give them moderator permissions. Try it yourself.
16 years 4 months ago #45481 by Mick
Cerberus wrote:
At top of your administration page you see the menu tabs one say COMPONENTS select that and from the drop down list select KUNENA, you are now in kunenas administration section and you will see a row of buttons abit like the joomla one now from them select USER ADMINISTRATION ( its the 3rd one along ). :)
If your still stuck see image below :)
This is what you do, nothing else.
Time to create page: 0.294 seconds
