Kunena 7.0.8 Released
Question How to assign a moderator to my Kunena forum
16 years 4 months ago - 16 years 4 months ago #44957
by Mick
How to assign a moderator to my Kunena forum was created by Mick
Can someone please tell me how to make a member into a mod? Mod doesn't seem like an option in the groups thing.
Link to my forum...
www.nikkershaw.net/fan-forum
Link to my forum...
Last edit: 16 years 4 months ago by sozzled. Reason: Changed subject to improve search relevance
16 years 4 months ago - 16 years 4 months ago #44961
by Cerberus
in admin sectio of kunena go to USER MANAGER then select the user you want to make a mod and then change there RANK setting to MODERATOR
and your done..
Last edit: 16 years 4 months ago by Cerberus.
16 years 4 months ago - 16 years 4 months ago #44987
Replied by sozzled on topic Re:How to assign a moderator to my Kunena forum
The solution is not quite as Cerberus has described. The assignment of a user as a forum moderator is achieved with the Kunena User Administration control in the backend. I started to write some notes for the documentation Wiki but, somehow, my work was lost; I failed to regain sufficient enthusiasm to do the work again.
There are two types of moderators: those who are assigned to specific moderated categories and those who are "global moderators" who have moderator privileges across all categories in the forum. The assignment is achieved through the User Administration function and the following screenshot illustrates what you need to do:
As you see, it's not a case of assigning the rank of "moderator" (in fact it's better to use the "no rank assigned" option) but instead you set Is Moderator = Yes.
Optionally, you may select one or more categories from the list to the right of this setting. Selecting specific categories will assign the user to moderate those categories (and no others). If you do not select any categories, the user will be a "global moderator" with associated privileges across all categories.
16 years 4 months ago #45004
by Mick
Replied by Mick on topic Re:How to assign a moderator to my Kunena forum
Where do I find User Administration? I can only find User Manager and I can't do what is needed from there.
Time to create page: 0.271 seconds
