Merged How to install a language when using Kunena 2.0.2
14 years 2 weeks ago #136284 by oldfart
Doesn't really help.
The Wiki (which I had read before attempting to install the language files) does not give any advice for Kunena 2 with Joomla 2.x
'download and extract it' .. to where??
thanks for the interest; I am surprised not more people want a multi-language site
14 years 2 weeks ago - 14 years 2 weeks ago #136285 by sozzled
(1) Download the translation package file joomlacode.org/gf/download/frsrelease/17...2.0.2_2012-09-02.zip to your PC
(2) Extract the files on your PC. This is what sjaak meant when he wrote "download ... and extract"
(3) After downloading and extracting, I guess what sjaak meant with "select" is to locate the specific translation that you need from the files that you have downloaded and decompressed on your PC. Then all you need to do is install the language(s) that you need in the usual manner.
I'm using intuitive guesswork here. When you have successfully completed the activity, oldfart, maybe you could help us with a detailed set of instructions we could put into the Wiki to help others? It would certainly save everyone's time in trying to learn the procedure, wouldn't it?
Last edit: 14 years 2 weeks ago by sozzled.
14 years 2 weeks ago #136289 by TKtemp
From README.txt file inside language package.
Installing languages in Joomla! 2.5
Just install this package by using Joomla installer. If you cannot install the package because of 2MB upload limit, you can either
install the package from URL or make the file smaller by removing a few languages you do not need.
Installer will detect which languages have been installed into your system. It will install or update only existing languages,
so If you add new languages after installing this package, you will need to install this language pack again.
Every language will be installed separately to allow you to uninstall them one by one if needed. You can find the language
packages by going to "Extension Manager: Manage", selecting type File and filtering results by "Kunena Language".
Additionally extension manager will have a package called "Kunena Language Pack". Uninstalling this package will also uninstall
all the languages that were added during installation.
14 years 2 weeks ago #136291 by oldfart
Hi Guys
Thanks for the help so far; managed to get a language installed (will do detailed write-up later).
But, now, how do I get Kunena to use that language??
14 years 2 weeks ago #136292 by TKtemp
Kunena display your JOOMLA default language ;)
The following user(s) said Thank You: sozzled, oldfart
14 years 2 weeks ago #136293 by sozzled
Thanks to both of you: oldfart and TKtemp :)
The following user(s) said Thank You: 810
Time to create page: 0.146 seconds
