Merged How to install a language when using Kunena 2.0.2
14 years 2 weeks ago #136294 by oldfart
TKtemp wrote: Hi,
Kunena display your JOOMLA default language ;)
So, despite having installed the language for Kunena; it has no effect, and you have to control Kunena's language using Joomla tools, where (in my case, with Spanish installed) I would have to install Spanish for Joomla and change default language.
I guess the Kunena specific words (haven't looked) will be in the Kunena spanish dictionary??
I can investigate this theory, but if you know the answer it will save some time.
14 years 2 weeks ago #136296 by sozzled
oldfart wrote: I guess the Kunena specific words (haven't looked) will be in the Kunena spanish dictionary?
It depends on how complete is the translation. According to the information here ( www.transifex.com/projects/p/Kunena/ ) it would seem that Spanish is 100% complete but, really, who knows?
14 years 2 weeks ago #136297 by oldfart
This guide is valid for Kunena 2.0.2 & Joomla 2.5.7
1. Download the language pack from the downloads section
http://joomlacode.org/gf/download/frsrelease/17387/75811/pkg_kunena_languages_v2.0.2_2012-09-02.zip
2. Unzip it (on your PC is easiest)
3. there is a directory called /languages, with a load of different languages for Kunena (as zip files) - select which one you want to install
4. Using JOOMLA's Extensions | Extension manager, Upload Package File;
upload the zip file you want to install. For this example I used Spanish:
com_kunena_es-ES_v2.0.2.zip
That's it for the Kunena part.
5. You now have to install Spanish into JOOMLA: Extensions | Language Manager - click the Install Language Icon and search for spanish, select it and click the install icon.
6. Go back to Extensions | Language Manager - Spanish should be in the list - select it and make it default.
That's as far as I have got - this is what it looks like
The following user(s) said Thank You: sozzled, TKtemp
14 years 2 weeks ago #136302 by sozzled
I made an attempt to update the Wiki with better information, based on what oldfart has given us. Please review the article K 2.0 Language Installation Guide and add/update it as you see fit.
14 years 2 weeks ago #136303 by TKtemp
Kunena language installer detect which languages are already installed on your Joomla site and install all present languages from package.
So, the right way to install kunena language (J!2.5) should be:
J!2.5
1. Install Spanish language for Joomla and make it default
2. Download language package from Kunena site
3. Install this package using Joomla Extension Manager
If installation fail:
4. Extract the files from the archive and install language file you wish using Joomla Extension Manager
J!1.5:
steps 1, 2 and 4 (step 3 doesn't work)
Best Regards
14 years 2 weeks ago - 14 years 2 weeks ago #136304 by sozzled
You are quite correct - the order of installation is important - and I have updated the documentation accordingly.
Last edit: 14 years 2 weeks ago by sozzled.
The following user(s) said Thank You: oldfart
