Idea SOLVED: NOT SOLVED: BBCode legend (Help) doesn't work
You need to follow the procedure carefully; it's easy to make a mistake and discover that you've made no improvement.
- Examine the directory ../components/com_kunena/templates/defaul/js
- there are two files, one called kunenaforum.js (which is 4467 bytes) and the other called kunenaforum.min.js (which is 4323 bytes);
- delete kunenaforum.min.js
- make another copy of kunenaforum.js and rename the copy as kunenaforum.min.js
- you should now have two identically-sized files (of 4467 bytes) in your directory called kunenaforum.js and kunenaforum.min.js
I tried this solution before I made this original post. Then I tried it again just now. No change for me.
Where are you finding your kunenaforum.js file? I took mine from com_kunena_v1.0.10_stable_b1344_2009-05-21, but it is only 4.22kb.
I will paste my file below.
Can you please paste your kunenaforum.js file?
Thanks!
I think you'll find that the file I'm attaching will be identical to yours.
Yep, seems to be.
Just in case, I tried it 2 more times. The first time, I cut and pasted your file content into my files.
Then the second time, I uploaded and renamed your file.
My problem persists.
So are you thinking it is a javascipt conflict with some other extension?
Can I just go back to the plain old popup tooltips?
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
I just checked one of my other sites that is J1.5.10 and K1.0.8 and discovered that the function examples work for the stuff on the second row (spoiler and ebay) but not for any of the stuff on the top row (bold, italic, underline, etc).
I will upgrade to 1.0.10 now and see if it behaves the same as the ORRRC site.
UPDATE: Yep, it behaves the same as the ORRRC site.
