Idea SOLVED: NOT SOLVED: BBCode legend (Help) doesn't work
Big thank you!!!!, really. This was _the fix_ to my site problem. I hope you will find the soluton. Maybe uninstall rokcandy and re-install gain after testing.
Regards!
Hi:
Regards!
OK, was your problem that the legend (aka: tool help) did not work, or did the tool function itself not work?
Just to clarify, when the rok candy basic macros are enabled, I lose the functionality of the tools. With basic macros disabled, I regain functionality of the tools, but my legend does not work.
Latino, can you please verify whether or not your tool legend (the tool help that should display in the yellow box) is working?
The legend is not working, my big problem were the tools. The BBCODE now works. We have same situation. But without the tools forum was useless, and you provided the fix!
Regards!
Hi:
Regards!
OK, then you and I both share the same situation now. My guess is maybe an RT extension is causing js conflict. Other than Rok Candy, what RT extensions are you using?
I use rokweather, rokajaxsearch, rokstories, rokbox, roktabs, roktwiter, roknewspager, roknewsflash. The problem should be something system-wide. for the forum I dont have those modules active at it. So that makes it difficult to identify. I also run CB 1.2.1 so mayba a CB plugin could be the cause (if you have CB 1.2 too).
I tried disabling rokbox, rokcandy plugins. Nothing changed.
I fairly convinced that Joomla has a bearing on this problem. Joomla 1.5.10 brought many security changes aimed at preventing badly-formed or malicious Javascript exploits. J! 1.5.11 has built on those foundations. Good thing too!
This is my personal experience of the problem:
- Local PC development site: J! 1.5.7 website, K 1.0.10, CB 1.2.1, JEvent 1.5, JA_Purity template - BB tooltips work.
- Beta test site: J! 1.5.7 website, K 1.0.10, CB 1.2.1, JA_Purity template - BB tooltips work.
- Production site: J! 1.5.10 website, K 1.0.10, CB 1.2.1, govista template - BB tooltips did not work until I implemented the fix described in message #18844 .
- Production site: J! 1.5.10 website, K 1.0.10, JEvent 1.something, RocketTheme template - BB tooltips does not work even after implementing the abovementioned fix; changing to rhuk_milkyway template has no effect either.
- Secondary site: J! 1.5.10 website, K 1.0.8 - half the BB tooltips work but half of them don't. ( #18896 ); after upgrading to K 1.0.10 the behaviour is identical to the production site.
