Idea SOLVED: NOT SOLVED: BBCode legend (Help) doesn't work
I get a popup tooltip for Bold, no tooltips at all for anything else, and my yellow box is stuck with the message that says, 'bbCode Help - Hint: bbCode can be used on selected text!'.
I've tried uploading a new kunenaforum.min.js file (found in another post) and I've tried copying and renaming the kunenaforum.js file (found in another post). Neither worked.
The site is here:
www.orrrc.org/runners/forum.html
Any ideas??
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
"The administrator has disabled public write access."
Might be a JS conflict. Does it occur on the default Joomla templates?
grumblemarc wrote:
It does nothing to post a link when you cannot actually view the problem.
Same as this Kunena forum. You can create a free user account easily enough.
Yes, still happens with rhuk_milkyway.
@JComeskey: do you have a test user account that would help to see the problem?
Good idea! Try:
Username: testuser
Password: kunena
Thanks!!
K 1.0.10 on a J! 1.5.10 website (also using JEvent components).
However, I don't have these symptoms on a J! 1.5.7 website with K 1.0.10 and JEvent. I'll dig more into this matter tomorrow - see if the kunenaforum.min.js is involved.
Cheers
sozz
