- Thank you received: 3
Question Templating changes 1.0.9 > 1.0.10
- grumblemarc
- Elite Member
- Still making trouble
What comes to K1.0, there will not be any major change after this. This is because if we will release another version from K1.0, it will only be a small security fix release & removal of the warnings and few regression bugs.
But what comes to template changes in general: You must redo your templates first for K1.5 and later for future versions (MVC). I have tools to automate most of the conversion from K1.0.10 to K1.5.2, but some manual work is needed. How much, I haven't investigated yet.
Mahalo,
JBHawaii
There is a very high likelihood that your modified template will be incompatible with, and cause problems for, Kunena 1.0.10; however, the likelihood is not a 100% certainty. The "templating" issue may be a show-stopper for some people moving to K 1.0.10; on the other side of the coin, there were enough defects in earlier versions of Kunena to make the choice to upgrade a simple one.I'm using k1.0.9 with a modified default template, (Not Default_Ex) will it be compatible with k1.0.10 or will I too have to modify a new template from scratch?
Btw, I did try to just use the template I modified... as expected it was a no go! seems there are serious changes to the templates from 1.0.9 -> 1.0.10.
Mahalo,
JBHawaii
docs.kunena.com/index.php/Kunena_1.0.10_...Me/#Short_Change_Log
Thats also why you cant take your old template..but when you only changed the css file and the images you can copy all php files from default_ex 1.0.10 and it should work.
Kunena Contributor & Language Coordinator
Kunena Birthday Module | Kunena LaTeX Plugin | SchuWeb Sitemap with free Kunena Plugin
Always up to date with Twitter
