Question Templating changes 1.0.9 > 1.0.10
17 years 5 months ago #17967 by Matias
Kunena 1.0.10 is a security release and it fixes some nasty bugs that will allow your users to inject code (which is run in their browsers) into your forum. That's the main reason why you should think about upgrading. But it's your decision.
If your changes in template are small, just get some good diff tool from the net and run diff against 1.0.9 default template. It shows you all the changes and makes it easy to add them to K1.0.10.
17 years 5 months ago #18029 by JBHawaii
Thanks Ida, and Matias I have made the transition and built a new template from scratch for k1.0.10, Must say can't see much difference. I do however, like the new BBCode block it really tidy up the UI.
Also in one of my posts I mentioned how the redirect really annoys my users. I hope there will be plans soon to rectify the redirect issue of taking you to the last post of the thread, rather then back to the same message or page you were editing.
Anyhow as mentioned by several members having to redo the template was worth the time considering the security fixes.
Mahalo,
JBHawaii
Mahalo,
JBHawaii
