Kunena 7.0.8 Released
Question Upgrade from 1.07 to 1.08
- Oscarfishlover
- Premium Member
The #1 Oscar Fish website on the net
Joomla! 2.5.14
Kunena 3.0.2
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
Can I upgrade from fireboard 1.05 straight to kunena 1.08, or do I have to install 1.07 first and then go to 1.08 ?
Yes same upgrade procedure. Our upgrade code does all the necessary incremental.
fxstein
Incorrect. Nothing gets removed from the database. Only files from the server. This morning I uninsalled 1.0.7 and reinstalled 1.0.8. Nothing is lost. BUT...if you are unsure you should ALWAYS make a backup of your database before you do anything.
Tks for your reply, so can I do it as:
- Backup Joomla database (by JoomlaPack for example)
- Login in Joomla by administrator (<joomla root>/administrator/)
- Extension/Uninstall Kunena Forum
- Download 1.08 version at here
- Install again.
Is it correct?
Thanks in advance.
Good luck!
fxstein
Thanks for your reply - I upgraded already - Thanks for very good module.
