Important Problem When Clicking Some Members Names
17 years 6 months ago #16826 by sozzled
G'day, KaySee. I'm pleased to read (even though you had to do a few tricks like a performing seal - re-enabling then disabling a couple of Kunena settings) that your forum page now loads correctly. Just to be sure I understand the current situation: the "problem when clicking some members' names" issue has been resolved? That's what I'm particularly interested in knowing.
When I've read confirmation that your original problem has been solved, I'll investigate more into the second problem that you've reported but, I think it would be much better for all concerned if you opened the second problem (the "vanishing message forum") as a new topic.
17 years 6 months ago #16830 by KaySee
Well from what i can see so far it is. but when you click the Clickable Numbers of howmany members there are, it only displays Afew and not all of them
17 years 6 months ago #16835 by sozzled
When you write "clickable numbers" I assume you mean when you click "user list". Is that correct?
I see, from your website, that when a user clicks the user list, it displays the first 10 users (of a total of 54) but no more. Is this the symptom you're referring to? If this is the case it's perhaps (technically-speaking) another, different problem. I mean, did this [abbreviated-to-ten-usernames] problem exist before you upgraded to K 1.0.10?
Just to be crystal-clear that I understand what the current situation is: the error messages that you reported in your original message no longer occur as a result of upgrading to K 1.0.10, yes?
17 years 6 months ago #16836 by KaySee
Yep you got it :-),
and yes it was before i upgraded.
17 years 6 months ago #16842 by sozzled
Thank you, KaySee. I'm sorry to seem like a pain, but I wonder if you could do us another small favour, please: you now seem to have another new, unrelated problem to your original message - the user list is truncated to 10 (out of 54) registered users.
Could you please start another new topic on this new problem.
I'm pleased to see that we've identified the cause of your original problem which was initially due to a conflict with the defective Community Builder cbsimpleboardtab plugin and compounded by Kunena's "integration" settings (as I first suspected was the case). I'm also pleased to see that the original problem, as reported, has now been resolved. I'm sorry to read that you experienced a new problem as a result of upgrading to K 1.0.10 and that you had another pre-existing problem that was not fixed by the upgrade.
