Important Problem When Clicking Some Members Names
17 years 6 months ago #16650 by KaySee
already done it :-)
and i resent that comment on the Negligble content. may not be much but alot of work has gone into that :-)
17 years 6 months ago - 17 years 6 months ago #16652 by sozzled
*heh-heh-heh @ "negligible content"* I know ... you've put a lot of effort into what you've achieved. ;)
EDIT: I see that something has changed with your website: you now have the error message "Fatal error: Call to a member function loadPluginGroup() on a non-object in /home/audioche/public_html/acradio/components/com_kunena/lib/kunena.communitybuilder.php on line 124." Why is kunena.communitybuilder.php trying to load if Community Builder has been uninstalled?
Last edit: 17 years 6 months ago by sozzled.
17 years 6 months ago - 17 years 6 months ago #16657 by Matias
Do you have CB 1.2 or CB 1.1? We support only new one..
Hmm.. You need to upgrade to CB 1.2.1 to get it work right. We just found out that CB 1.2.0 forum plugin had a bug (using deprecated configuration file) which is triggered in Kunena 1.0.10 (which has also a small bug in that configuration file).
It's easiest to fix in Kunena: administrator/components/com_kunena/admin.kunena.php line 846 from:
$txt = "<?php\n";
to
$txt = "<?php\n"."global $mainframe;";
Last edit: 17 years 6 months ago by Matias.
17 years 6 months ago #16659 by sozzled
Thank you, so much, Matias! *phew* ... I was beginning to wonder if I'd made the right suggestion to upgrade to K 1.0.10.
But I'm puzzled. Why would K 1.0.10 cause problems if the user doesn't have Community Builder installed as he claims? And, was Community Builder the root cause of the problem as first reported - as I maintained it was - anyway?
17 years 6 months ago #16664 by Matias
We are using CB detection code which was suggested by CB team.
It looks like that in this case CB is installed, but disabled by Joomla 1.5. We need to investigate what is happening in there..
17 years 6 months ago - 17 years 6 months ago #16667 by sozzled
I agree. :) I'm unconvinced the user has uninstalled CB from his website. I still think the original problem was caused by the flaky cbsimpleboardtab plugin. FYI: I installed K 1.0.10 on a test site (with Community Builder installed - with the Tony Woodhouse modification) and everything works well. :woohoo: We could wait until CB 1.2.1 if/when it sees the light of day, but there's no other restrictions in installing K 1.0.10 in the meantime (with the usual caveats). :)
