Important Problem When Clicking Some Members Names
17 years 6 months ago #16621 by KaySee
I am currently having the problem that when you click on a user at the bottom of the forum (like a new user) for some reason the page goes wild, and displays a white page with the following errors below in different tables.
Thankyou
Recent Discussions
My Discussions
Categories
My Profile
Welcome, DJ KaySee
Show Latest Posts | My Profile | Logout | Announcements
variable value
$0 "key value
$file "/home/audioche/public_html/acradio/components/com_kunena/lib/kunena.debug.php"
$line "42"
$function "debug_callstackinfo"
[args] Nested Array
$1 "key value
$file "/home/audioche/public_html/acradio/components/com_kunena/template/default/plugin/fbprofile/fbprofile.php"
$line "60"
$function "trigger_dberror"
[args] Nested Array
$2 "key value
$line "36"
$function "showprf"
[args] Nested Array
$3 "key value
$file "/home/audioche/public_html/acradio/components/com_kunena/kunena.php"
$line "603"
[args] Nested Array
$function "include"
$4 "key value
$file "/home/audioche/public_html/acradio/libraries/joomla/application/component/helper.php"
$line "162"
[args] Nested Array
$function "require_once"
$5 "key value
$file "/home/audioche/public_html/acradio/includes/application.php"
$line "124"
$function "renderComponent"
$class "JComponentHelper"
$type "->"
[args] Nested Array
$6 "key value
$file "/home/audioche/public_html/acradio/index.php"
$line "68"
$function "dispatch"
$class "JSite"
$type "->"
[args] Nested Array
Installed version: 1.0.8 | 2009-02-17 | 1166 [ Speakup! ] | php 5.2.6 | mysql 5.0.77-community
Fatal error: Unable to get user info.\nDB function reports no errors in /home/audioche/public_html/acradio/components/com_kunena/lib/kunena.debug.php on line 54
17 years 6 months ago - 17 years 6 months ago #16625 by sozzled
Gday, KaySee. Yes, this is the same problem you reported a month ago ( Problem When Clicking On Username ). I don't think the advice you were given then was suited to your problem.
I believe the problem is cause by the use of the standard Community Builder cbsimpleboardtab plugin. If you disable the plugin the problem should go away. Alternatively you can replace the cbsimpleboardtab plugin with the Tony Woodhouse solution that we discussed earlier today (see /forum?func=view&id=16604&catid=12#16610). Another way to solve your problem is to change the Integration choice that you made in your Kunena configuration settings (see Configuration Tips ).
Last edit: 17 years 6 months ago by sozzled.
17 years 6 months ago #16627 by KaySee
I Must have forgot i reported it :-( Must have just gave up and tryed CB.
But CB Is Not Installed Anymore. So That's Not The Problem :-(
17 years 6 months ago #16630 by sozzled
The fact that CB isn't installed may still, very well, be the problem! Change your Integration settings (as recommended in docs.kunena.com/index.php/Configuration_Tips#Integration ) and things should work.
17 years 6 months ago #16634 by KaySee
They all Say Kunena
17 years 6 months ago #16635 by sozzled
Have you enabled "announcements" ... and the other recommended values given in the "configuration tips"?
