Question minimum system requirements for install?
17 years 8 months ago #6330 by fxstein
careful how you check the MySQL version. If you look at phpMyAdmin it will tell you the client version not the database one. You have to check the database version.
We have only added the checks in 1.0.8 since too many users did not check the tech requirements themselves, which led to broken installs.
We use this SQL to check for the version:
SELECT VERSION() as mysql_version
It will tell you what version of MySQL your server is running on.
Let us know.
Thx!
fxstein
17 years 8 months ago #7065 by dojo
I think I'm experiencing an issue tied to the MySQL version. I use MediaTemple for hosting and they require a beta application to use MySQL 5.x.
I got some install errors (from the 1.0.8 version check) and so I uninstalled, toggled PHP to v5 and re-installed. I still got the INSTALL CHECK ERROR.
php version: 5.2.6 Required >= 4.3.0
mysql version: 4.1.25-Debian_mt1 Required >= 5.0.0
I figured I'd try and see if Kunena would work with the MySQL that was available to me.
Surprise! It DID NOT. :-(
I got this error the first time I clicked through from my Main Menu item to Kunena's front end. I thought it might be helpful for you to see it, even though it's all Greek to me.
Table 'db10099_client.jos_fb_whoisonline' doesn't exist SQL=INSERT INTO jos_fb_whoisonline (`userid` , `time`, `what`, `task`, `do`, `func`,`link`, `userip`, `user`) VALUES ('0', '1236038234', 'Forum Main','','','','/index.php?option=com_kunena&Itemid=112', '69.232.205.1', '0') variable value $0 " key value $file "/home/10099/domains/clientsite.com/html/components/com_kunena/lib/kunena.debug.php" $line "42" $function "debug_callstackinfo" [args] Nested Array " $1 " key value $file "/home/10099/domains/clientsite.com/html/components/com_kunena/lib/kunena.debug.php" $line "62" $function "trigger_dberror" [args] Nested Array " $2 " key value $file "/home/10099/domains/clientsite.com/html/components/com_kunena/kunena.php" $line "451" $function "check_dberror" [args] Nested Array " $3 " key value $file "/home/10099/domains/clientsite.com/html/libraries/joomla/application/component/helper.php" $line "162" [args] Nested Array $function "require_once" " $4 " key value $file "/home/10099/domains/clientsite.com/html/includes/application.php" $line "124" $function "renderComponent" $class "JComponentHelper" $type "->" [args] Nested Array " $5 " key value $file "/home/10099/domains/clientsite.com/html/index.php" $line "68" $function "dispatch" $class "JSite" $type "->" [args] Nested Array " Warning: Could not load latest Version record.\nDB function failed with error number 1146 Table 'db10099_client.jos_fb_version' doesn't exist SQL=SELECT `version`, `versiondate`, `installdate`, `build`, `versionname` FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 1; SQL = SELECT `version`, `versiondate`, `installdate`, `build`, `versionname` FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 1; in /home/10099/domains/clientsite.com/html/components/com_kunena/lib/kunena.debug.php on line 69 Installed version: | | [ ] | php 5.2.6 | mysql 4.1.25-Debian_mt1 Fatal error: Unable load accessible categories for user.\nDB function failed with error number 1146 Table 'db10099_client.jos_fb_version' doesn't exist SQL=SELECT `version`, `versiondate`, `installdate`, `build`, `versionname` FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 1; SQL = SELECT `version`, `versiondate`, `installdate`, `build`, `versionname` FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 1; in /home/10099/domains/clientsite.com/html/components/com_kunena/lib/kunena.debug.php on line 54
Note... I replaced my client's site with "clientsite.com" and client in the DB name for confidentiality reasons.
FOr now I think I may have to go with PHPbb3 and a bridge just because I can't easily get MySQL 5.x on MediaTemple. I'd much rather use Kunena but them's the breaks for now I guess. :-(
17 years 8 months ago - 17 years 8 months ago #8262 by lightinthedark
I'm new in here so sorry if this is out of place.
I was having installation trouble (similar to a couple of posts in this thread, and most of this one www.kunena.com/forum?func=view&catid=16&id=7764 ) . I could run the installation, but it'd flake out part way through. When I went to look at the component control panel I saw pretty much the same thing as dojo there. I looked at the database and saw that only 3 (or on some attempts 4) tables had been made.
I did a fresh installation on my dev server at home with the minimum requirements observed (max_execution_time =120 , memory_limit 64M) and it went in fine. I then took a dump of the jos_fb_... tables, ran the installer on my actual site (which failed as usual), went to the database and removed the fb tables, then ran the dump of the tables created on my dev box. I've not probed too deeply, but it seems to have worked. I get the control panel page without any errors, and the site side appears to be displaying right.
I've attached my dump in case anyone else wants to try the same thing and doesn't have their own webserver at home :-) I hope this helps someone.
Good work on the forum chaps, keep it up. When you're done making a 1.5 native version, how about slimming the installer down a bit ... and get it to make my coffee :P
Hello
:-Dave
File Attachment:
File Name: dump.zip
File Size:5.66 KB
Last edit: 17 years 8 months ago by lightinthedark.
17 years 8 months ago #8266 by grumblemarc
No need. Install and run Joomlpack on the local server and install the Joomlapacj archive on the remote one.
