Question minimum system requirements for install?
17 years 9 months ago - 17 years 9 months ago #1447 by korri78
Hi, guys~
nice to see you guys here again!
I've used FB more than a year.
Recently, I moved to new web hosting company.
And I realized that FB and Kunena is not installed... :dry:
The only thing I could suspect is the minimum system requirements for install.
New host provides php 4.4.9 and database 5.0.67
doesn't it satisfy the condition?
or... what can make Kunena installation failed? :S
p.s.
Joomla 1.5.9
Legacy enabled
Last edit: 17 years 9 months ago by korri78.
17 years 9 months ago #1449 by fxstein
You need php 4.3 or higher and mysql 5.0 or higher - so that seems fine.
Make sure your php timeout is set to 120 sec. The installer of Joomla 1.5 takes a while to upload and unzip the archive. If it hits the timeout it quietly dies, without any errors or messages.
Hope this helps!
fxstein
17 years 9 months ago #1451 by korri78
Thanks for quick answer!
I tried to find the php timeout setting.. but couldn't... :blush:
Could you tell me where I can find the php timeout setting to change??
17 years 9 months ago #1472 by korri78
I got this error message...
Have no idea what happened...
anybody can help?!!
Fatal error: Allowed memory size of 15728640 bytes exhausted (tried to allocate 7680 bytes) in /www/xxxx/libraries/joomla/utilities/simplexml.php(302) : eval()'d code on line 1
17 years 9 months ago #1485 by Matias
16M memory limit isn't enough for Joomla. I recommend using 64M limit in your php.ini.
17 years 8 months ago #6307 by metaltome
I just downloaded 1.08 Stable and installed. It is telling me that the Install Failed due to System Requirements. It's saying I don't have PHP 5.1.6 and the required SQL version, yet I checked my server and I have all the required versions. Any idea why it would be doing this? 1.07b installs perfectly. So I'm somewhat confused, as I know for a fact I meet the System Requirements on my server. It is a dedicated server that I run myself.
