Question minimum system requirements for install?
nice to see you guys here again!
I've used FB more than a year.
Recently, I moved to new web hosting company.
And I realized that FB and Kunena is not installed... :dry:
The only thing I could suspect is the minimum system requirements for install.
New host provides php 4.4.9 and database 5.0.67
doesn't it satisfy the condition?
or... what can make Kunena installation failed? :S
p.s.
Joomla 1.5.9
Legacy enabled
You need php 4.3 or higher and mysql 5.0 or higher - so that seems fine.
Make sure your php timeout is set to 120 sec. The installer of Joomla 1.5 takes a while to upload and unzip the archive. If it hits the timeout it quietly dies, without any errors or messages.
Hope this helps!
fxstein
I tried to find the php timeout setting.. but couldn't... :blush:
Could you tell me where I can find the php timeout setting to change??
Have no idea what happened...
anybody can help?!!
Fatal error: Allowed memory size of 15728640 bytes exhausted (tried to allocate 7680 bytes) in /www/xxxx/libraries/joomla/utilities/simplexml.php(302) : eval()'d code on line 1
