Question Installation Issue
17 years 9 months ago #1384 by whouse
Replied by whouse on topic Re:Installation Issue
Naukhez wrote:
...using joomla 1.0.5
I do hope this is a typo as Joomla 1.0.5 hasn't been available for a LONG time. I am really hoping that you are using the latest version of Joomla, whether it is 1.0.X or 1.5.X and you meant to say Fireboare 1.0.5. If you really are using Joomla 1.0.5, please, please think about upgrading.
17 years 9 months ago #1409 by Dalcielo
Replied by Dalcielo on topic Re:Installation Issue
whouse wrote:
It means that the installer couldn't create the version table for whatever reason. If it was already there, the installer can't create it again which would cause this error. Did you previously use Fireboard? If so and you dropped the tables, you may have missed this one. If the forum works fine and that was the only error you received in the install, you should be fine.
No.. I never installed FireBoard.
The forum seems to work well .. thanks all ;)
17 years 9 months ago #1443 by Naukhez
Replied by Naukhez on topic Re:Installation Issue
Hello there
Thank you for precious time people
1- i am using joomla 1.0.15 not 1.0.5 (my mistake) please forgive me for that
2- As fxstein asked about the component, how it is working now, the answer is the component is not working, it is showing almost blank page with only login information when click on any category, here is the picture (using default_ex template)
as Whouse mentioned It means that the installer couldn't create the version table for whatever reason. If it was already there, the installer can't create it again which would cause this error. Did you previously use Fireboard?
yes i do use fireboard previously but as i mentioned above in starting that i have dropped all tables remove all directories related to fireboard but still having this error,
now i think i have cleared almost whats going on with me, so its up to you guys, your suggestions are more then welcome
Regards
Naukhez
17 years 9 months ago #1444 by fxstein
Replied by fxstein on topic Re:Installation Issue
If you had FireBoard installed before, I would guess that you might have something overlooked during the manual cleanup. The create table does not fail without a reason.
I'd be happy to look into your system if that is an option.
fxstein
17 years 9 months ago #1510 by raniafekry
Replied by raniafekry on topic Re:Installation Issue
Hello
Any Help please , I been trying for a week to get it work , no luck
after installation , I got this error , table jos_fb_conf not exist
I am using joomla 1.5 last version of Kunena
I appreciate your kind respond
Thank you very much
Rania
17 years 9 months ago #1550 by Matias
Replied by Matias on topic Re:Installation Issue
You mean jos_fb_config? Did you set php timeout to be long enough (60 secs)? Intalling Kunena will take a lot of time and in some environments it timeouts and the installation fails without an error.
Try also to upload the file directly by providing url instead of uploading the file.
Time to create page: 0.200 seconds
