Question Installation Issue
17 years 9 months ago #1567 by PatchesPal
Replied by PatchesPal on topic Re:Installation Issue
Is this a manual installation method you are referring to? I am unable to adjust the timeout and have tried installing from a directory. My next option may be to install manually but I do not know how. Thanks,
17 years 9 months ago #1585 by Matias
Replied by Matias on topic Re:Installation Issue
No it's not manual. There is three choices how to install a component:
* by uploading it into your site from your own computer (very slow, do not use this)
* by uploading the file from URL (give link to the file)
* by running it from a local directory
First one is the slowest and the last one fastest. If you're using the first option, please try the others, too.
17 years 9 months ago #2275 by Naukhez
Replied by Naukhez on topic Re:Installation Issue
Issue is still there guys, is there any solution ??????
17 years 9 months ago #2362 by johnnydement
Replied by johnnydement on topic Re:Installation Issue
yes, ask joomla team for a better installation for 1.9.1 ;)
first, edit your php.ini (or ask your ISP for it) and modify timeout to 120
use some of the other install options matias said (2nd or 3rd)
Use joomlapack to make a backup of your site, put in on a local test server, install kunena, pack again, and install on your live server ;)
17 years 9 months ago #2363 by grumblemarc
Replied by grumblemarc on topic Re:Installation Issue
Joomlapack is what I recommened.
17 years 9 months ago #3013 by Naukhez
Nothing is working guys, just curious for kunena new version,
