- Thank you received: 2545
Solved "Quick Response" button does not work in Kunena Discuss
With the t4_bs5_blank templlate from JoomlArt it works a bit better.
I will try to discuss the problem on the forum of JoomlArt.
Signature:
Many thanks to Rich and the other advisors.
I asked a question about the problem with the "Quick Reply" button on the Purity III forum. It turned out, that problems with Purity 3 and Kunena had already been discussed there, though in connection with other issues. The solutions offered there did not help me.
Yes xillibit , bootstrap 5.x is loaded on the pages where the kunena discuss plugin is loaded, and if I make it in Aurelia to Off, is Kunena also "Off".
In order not to publish a site with a broken place, I wanted to make the "Quick Reply" button invisible using "visibility: hidden" in custom.css.
Unfortunately, this did not work out, since the "Action" button (etc. at the admin) also become invisible.
I would be grateful for advice on how to make only the "Quick Reply" button invisible.
Signature:
Thank you very much.
Signature:
